1 - 2 of 2 Posts
In case anyone did what I did and put factory bags over an aftermarket sissy bar bracket, you'll notice that the bags no longer contact the fender/frame. Not much of a problem normally, but I'm transporting some heavy items today and was hard pressed not to figure something out. The answer was front control arm bushings for a 92 Ford explorer. The hole diameter fits snugly over the stock rubber bumper. The outside diameter is a bit large, but if your frame protection stickers are positioned correctly, it just makes it. Best part is they're removable for when you're unloaded. Best I could do with parts that I'll otherwise never use.
Sent from my LG-H931 using Tapatalk
1 - 2 of 2 Posts
