1 - 7 of 7 Posts
installed the air intake last night and now when I start the bike up its almost at full throttle.( if I twist the handle it revs higher)
Only issue i had during installation was the throttle body felt loose after getting the stock filter removed. So I tightened it back up before continuing. Any suggestions before I take it back apart?
Take the tank back off and make sure both vacuum lines are attached. If you left one loose, a vacuum leak will do that.
Diamond member
Another poster a while back had same issue, after the same mod. But damned if I remember what it was...
Diamond member
Well that's kinda terrifying if that's the case.. hope no vacuum leaks develop with a rider on it!
Diamond member
Checked all the connections and still starting full throttle. No showing any codes
Do a search on the forum. I do remember it was some very simple in the other dudes case.. I feel really bad I don't remember what it was..
1 - 7 of 7 Posts
