The Indian Chieftain is a big motorcycle, designed to soak up the miles on the smooth highways of ‘Murica. The star of the show is the new Thunder Stroke engine, a mighty 111 cubic inch (1811cc) monster pumping out 119 ft-lbs of torque.
It’s a remarkably good-looking motor, and it caught the eye of Roland Sands, the man who can do no wrong when it comes to creating genre-bending customs. Sands has now tapped into Indian’s rich motorsport heritage, and slotted the Thunder Stroke into a vintage-style, boardtracker-inspired build: the Indian Track Chief.
There’s so much detail on this bike, it’s hard to know where to start. The single-side rigid frame is a masterpiece, hugging the engine just-so. It’s hand-fabricated from 4130 chromoly steel, finished in black by Olympic Powdercoating.
The frame is a perfect match for the black Paughco Leaf Spring Fork assembly, a fascinating contraption designed for customizers who want a vintage look with high-quality, modern construction. Tucked down low on the left side of the fork, near the axle, is a Fox DHX mountain bike shock—a component popular with riders on the World Cup downhill series.
“It controls the motion of the front end, and works really well,” reports Sands’ project manager Cameron Brewer. “The compression and rebound dampening of the shock is a perfect match to the rate of the leaf spring.”
Sitting above the frame is a hand-fabricated titanium tank; hidden below the frame is an aluminum belly pan. The engine internals are stock but there’s a Roland Sands Design Blunt air cleaner, a high-flow, low-profile fitment that doesn’t get in the way of your leg. The titanium pipes of the custom 2-into-2 exhaust system follow the lines of the V-twin snugly, and terminate in RSD Slant mufflers.
For more check it out here: Roland Sands x Indian: "Track Chief" | Bike EXIF
