1 - 8 of 8 Posts
I bought an Indian Rogue seat for my 2019 Roadmaster (compatible per Indian website)....but I don't know how to hook up the wiring. Does anyone have experience here?
Indian sells a wiring harness for adding a trunk to several of the models that don't originally come with a trunk and don't have the wiring already in the seat like the Roadmaster. I've never taken a close look at how the cable is attached to the Roadmaster seat but you may be able to remove it and use it with the Rogue seat. If not then you'll probably need to puchase the accessory cable. In any event, take a look at the accessory cable on the Indian site as they have installation instructions on how to route the cable listed down in the details for the cable.
Trunk Wiring Harness | Indian Motorcycle
German Rider
Just a guess, but I would assume, that you either need to buy the mentioned harness or to remove the harness from the original seat.
Cu,
Sven
Rogue isn't heated ....nothing to plug in ....i have a 2020 Chieftain Elite and its not heated from the factory so no plugs
Cu,
Sven
Agree with Sven. I just swapped out my RM extended with Rogue extended. Remove the cord from RM seat, disconnect the heated cord, plug cord back to trunk and attach seat to bike. Works great!
Reactions: Demolition Man
Here is the plug to heated switch. Removed my zip tie
594026
This pic shows the wire with the white label is what you would remove from RM seat.
594027
1 - 8 of 8 Posts
