Regards the NEED to pair a BT headset to RideCommand for CarPlay to function, and play audio thru the bike speakers...
I started to ask WHY on the Indian Corp FB page, then mid-rant stopped & did more reading elsewhere, gaining some insight.
Here’s the whole blurb, in case others are asking the same “WHY” question:
Indian- Thank You... lovin’ the Challenger & this RC update,,, but gotta ask: WHY require a BT headset of any type to allow CarPlay to function & play thru the bike speakers???
Wire-connected to the USB port with a 2-way charge/data cable,, check. That should be ALL that’s required for CarPlay to then rock the bike speakers.
Please eliminate the BT headset loop, it makes NO sense.
(then)
*I did some reading at various sites on this question “WHY the need for a BT headset!”?
Here’s what I found:
Apple has a requirement for all CarPlay systems regardless of vehicle -that there be a microphone and speakers present. The reason: a big part of CarPlay is the “hands free” capability of Siri, and you can’t use Siri without a microphone and speakers. So every CarPlay system requires microphone and speakers be present.
Guessing that Indian implemented CarPlay such that to meet Apple’s requirements, they require a headset to be paired with RC. (“Headset” can be small BT earbuds, even just 1, cuz it is a BT Receiver w/tiny speaker & microphone.)
What a little BT device does is make the RC system think there is a microphone & speaker paired with the system.
We do not need to actually have a helmet headset paired to use CarPlay. A small BT earbud will do... pair it, then put it in a pocket or saddlebag. (yeah its battery life will be limiting,, unless you can then store it somewhere and keep it charged.)
THEN-
With a BT “headset” paired, now we can SELECT the speaker source ...ie, select to play thru the bike speakers; and continue to use CarPlay for maps, etc -without having a helmet headset.
So bottomline maybe it wasn’t Indian just trying to make it a pain to use CarPlay. CarPlay requires a mic & speaker. Our bikes have speakers but no microphone... so what choices did Indian have? Make the RC believe a mic IS part of the system via a BT connection to a headset or earbud.
(then)
THEN-
