1 - 11 of 11 Posts
Diamond member
As title suggests, the Big Bore kit has been done to a 60! Very exciting to be able to have the low entrance cost of a 60, with 60 looks, but be able to play with the big brothers! What great time to be a rider!
91hp and 77ftlbs! Stupid flat torque curve,
Stock air box and stock muffs
SAE Numbers are 88.43 hp / 75.07 Trq
Should handily out perform any stock Scout 69.
The real question is what power levels are attainable with an S&S air cleaner and loud slipons - once retuned.
We also need verification that Revolution Performance is going to provide PVCX tune support for kit purchasers...?
Reactions: Hatt
Diamond member
No doubt!
With the equipment you mention, you basically have my Scouts numbers., because it basically becomes s my Scout... lol
Yes, as have been mentioned before, they will offer support..
Recent postings on the other 3 threads forced me to research the S60 vs S69 part numbers... The heads and cams have different part numbers.. So parity of performance results is "in question"..
Reactions: Hatt
Pretty impressive.
I hope the riders that shift in the 2500-3k range pay attention to the power gains and what rpm level they are at. ;)
The price of the kit plus installation has to be somewhat expensive. I wonder how close to the price of a 69 cubic inch Scout those costs would bring a Sixty to. For example a gloss black 2019 ABS Sixty lists for $9799 and a 2019 gloss black 69 cubic inch Scout lists for $12,299, a difference of $2,500. If the kit with installation comes significantly lower in cost than $2,500 then it might be a worthwhile expenditure.
Diamond member
pretty sure, they have only the difference of the finish for the heads that reflects the different PN. Not sure about cams. They don't look any different though upon quick check. But, as we know that doesn't mean they are the identical.. I do know they had a number change even for regular Scout's. When I needed a new, we (my dealer) noticed a new number for the 69.
But, you raise a good question. I'll see if we can't reach Polaris and see what we learn, if not, maybe we can sneak some info from the horses mouth, aka S&S on the cams.
Our Revolution Performance "spokesperson" , Racer212, indicated that the heads and cams are different between the S60 and S69, and that parity of performance results should not be expected..
As with you, I would expect the heads to be identical except for the external finishing. The cams having different part numbers is concerning though..
Diamond member
The kit is 1300. So there some head room,
However not everyone will need to have the work done from outside.
Diamond member
Discussion Starter · #11 ·
Parity? Nah. But negligible I expect..
1 - 11 of 11 Posts
