2014 Chief Vintage: There is a very small return spring (approx. 1/8" dia, 1/2" long) encapsulated in the front brake lever assembly. If you hyper-extend your lever forward you will distort the spring (example: while backing out the bike, you catch the lever on a stationary object and hyper-extend the lever forward). The result is a lever that flops forward beyond the original limits and fails to return to it's original resting position. To disassemble the lever, you must remove the cir-clip retainer and pull the pivot pin. Good practice includes replacing the cir-clip during reassembly.
My Indian dealer priced the spring at $12 US. Additionally, you cannot buy the cir-clip alone, but must purchase the clip and pivot pin as a package for $12.95 US.
However, Ace is the place, and charges 40 cents for a spring that works and 25 cents for cir-clip that is an exact match. Ace did not mandate that I replace my perfectly good pivot pin.
I'm not here to argue corporate pricing margins. I'm just here to help out others that might also be on a fixed income.
