Hi All,
I am trying to install the FMB Mayhem 10 inch ape handlebars. The dealer quoted me about $1000!
I am quite a handy man, so decided to DIY. Since this is a ABS model, i need to replace the stock cables, and bleed brake fluids and access the ABS module to change the cables. I am stuck at the point where i need to remove the battery tray. Looked like a 4 bolt removal and pulling it out was the instructions. I am not able to pull it out of the motorcycle. It should be simple.
Can anyone help with suggestions on what i might be doing wrong?
