1 - 6 of 6 Posts
I replaced my stock Chieftain windshield with an aftermarket one (Freedom Shields- highly recommend). Of course I dropped one of the square washers from the back of the windshield and it fell behind the fairing. I know where it landed and it's not recoverable. Thankfully replacements aren't expensive and hopefully it will ship quickly.
Then, of course, I realized I needed to make an adjustment and would have to remove the screws and washers again. This time I did it right and stuffed an old t-shirt into the space in the fairing in front of the windshield. Yes I dropped a screw that time but the t-shirt caught it and kept it from falling behind the fairing.
If you're going to take a windshield off, do yourself a favor and stuff that space with rags to catch whatever you drop.
A trick I use is to put a dab of black RTV on the square nut. Reinstall it then after it cures everytime you remove the screw the square nut stays put. If you ever do want to remove the nut. Just loosen the screw about half way and push in on it. The nut will pop right out.
1 - 6 of 6 Posts
