I put an Ultimate tall boy seat on my 2017 Springfield. Nice seat, but now my reach to the handlebars is a little further than would be comfortable on a long ride. I cannot find a reduced reach handlebar for the 2017. Anyone know of one?
I looked into risers. It seems that risers won't work with the Springfield without major mods. Extended handlebars ? Is that the same as reduced reach ? There do not seem to be any for the 2016 & 2017 Springfield.Any options for risers to adjust the reach of the handlebars, too? I put some on my Honda I had and it was perfect. I don't know if it was really necessary my test ride was only like 4 miles on my Roadmaster, but I had the dealer put on extended handlebars. It's nice and relaxing with the throttle boss tabs I put on the grips too. Tried to google a pic of the handlebars, and if that chrome cover is over them, I'm not sure how it would be. But an option maybe?
I've seen comments about being able to move up/down a total of 2 inches. I like em where they are height wise. I want them back towards the rider.I would guess extended handlebars and reduced reach are the same thing. They extend, to reduce your reach. I had them put some extended ones on my RM. No idea if they'd fit on a Springfield, but if the bar diameter is the same and I guess it could be possible it could work if they clamp down on some kind of riser or whatever the attachment point is? But I guess you'd have to account for everything else, grips, levers etc. being able to mount up. I wish I knew more about Springfields to be able to think of some ideas to try and help. There's no way to loosen the current handlebars in their risers, and adjust it up or down to see if it changes your comfort at all?
I looked into risers for my 17 Springfield. Would be nice but I'd have to have custom cuts made to the top of the nacelle. I haven't looked into that yet. I put 4" risers on my 99 Vulcan Classic and they worked well. My Indian dealer here in Mi found a dealer in CA that had what they say was the last set of reduced reach handlebars for the 14-17 models available in the states. They are no longer in production. I snatched them up without a thought and just prayed FedEx didn't lose them! I just received them today. I haven't installed them yet, though I took some measurements. They have about a 2" longer rise but they are about 2" wider at the grips. Also, the grip doesn't have as much downward angle to them either. To be honest, I don't know if I'll gain a thing since my reach will be farther out and knuckles turned up.I looked into risers. It seems that risers won't work with the Springfield without major mods. Extended handlebars ? Is that the same as reduced reach ? There do not seem to be any for the 2016 & 2017 Springfield.
Let me know - I am jealous.I looked into risers for my 17 Springfield. Would be nice but I'd have to have custom cuts made to the top of the nacelle. I haven't looked into that yet. I put 4" risers on my 99 Vulcan Classic and they worked well. My Indian dealer here in Mi found a dealer in CA that had what they say was the last set of reduced reach handlebars for the 14-17 models available in the states. They are no longer in production. I snatched them up without a thought and just prayed FedEx didn't lose them! I just received them today. I haven't installed them yet, though I took some measurements. They have about a 2" longer rise but they are about 2" wider at the grips. Also, the grip doesn't have as much downward angle to them either. To be honest, I don't know if I'll gain a thing since my reach will be farther out and knuckles turned up.
I let you know. May be a minute before I get them installed. Had hand surgery yesterday and I'm wearing a mitten! I tried a set from a 16 Roadmaster but that didn't get me where I wanted. A touch more rise but wider. Pulling that Nacelle apart wasn't fun. Easier the second time when I put the stock ones back on. Have you tried moving them up or down? Moving the stock bars down helped me a little.Let me know - I am jealous.
The bars are 1 1/4". That chrome (nacelle) is two piece, front and back. The half closest to the tank holds the switch for the light bar and covers a multitude of ugliness (wire harnesses, light bracket, connections, etc...) The front is obviously the headlight. The only way to get risers in there would be to cut holes in the top. Keeping the two M5 screws that help hold the front and back together, the new risers would have to be tall enough to clear the top of the nacelle.So if you used some aftermarket riser or extension, I'm guessing that chrome cover won't go on and I don't know if it's integral to hold the headlight bucket on etc. But food for thought if you can get something to work and not care about that chrome cover being there to make the handlebars how you want. Just have to find the right diameter for the bars and how much closer you want them. Whew!
Rox Speed FX 2″ Black Pivoting Handlebar Risers - 4R-P2CC01
www.jpcycles.com
Actually they are completely opposite. Look up reduced and extended reach seats. Extended is for taller riders, reduced for shorter. I had reduced reach seat,handlebar and foot controls on my scout.I would guess extended handlebars and reduced reach are the same thing. They extend, to reduce your reach. I had them put some extended ones on my RM. No idea if they'd fit on a Springfield, but if the bar diameter is the same and I guess it could be possible it could work if they clamp down on some kind of riser or whatever the attachment point is? But I guess you'd have to account for everything else, grips, levers etc. being able to mount up. I wish I knew more about Springfields to be able to think of some ideas to try and help. There's no way to loosen the current handlebars in their risers, and adjust it up or down to see if it changes your comfort at all?
Just went through the same struggle, Indian of Racine, WI had a couple and I bought one, so maybe check them out.I put an Ultimate tall boy seat on my 2017 Springfield. Nice seat, but now my reach to the handlebars is a little further than would be comfortable on a long ride. I cannot find a reduced reach handlebar for the 2017. Anyone know of one?
