Only 2,647 miles. LIKE NEW with transferable extended WARRANTY.
Priced for a quick sale by private owner.
$17,850 is more than $1,000 less than any comparable Springfield on Cycle Trader.
Includes accessories that cost $2,000.
I intend to sell to best offer before end of the year. No trades. Cash only. Clear title in my name.
Call or text. Leave message. 918-855-9122, Dale.
Tulsa, Oklahoma
Driver and passenger backrests, sissy bar and luggage rack.
Metallic Jade over Thunder Black
Ride Modes
Rear Cylinder Deactivation
Quick release windshield
Genuine leather seats
Remote-locking saddlebags
Adjustable passenger floorboards
ABS
Electronic cruise control
Keyless ignition
Tire pressure monitoring
ENGINE: THUNDER STROKE® 111
Engine Type 49˚ V-Twin
Transmission 6-speed/constant mesh/foot shift
Battery 12 volts / 18 amp/hour, 310 CCA
Charging System 42 amp max output
Cooling System Air
Displacement 111 cu in
Exhaust Split dual exhaust with crossover
Final Drive Belt drive
Fuel Capacity 5.5 gal
Fuel System Electronic fuel injection
Oil Capacity 5.5 qts
Primary Drive Gear drive wet clutch
Torque 119 ft-lbs at 3000 rpm
SUSPENSION
Front Suspension Telescopic fork, 46 mm diameter, 4.7 in (119 mm) travel
Rear Suspension Single shock 4.5 in (114 mm) travel, air adjustable
CHASSIS
Dry Weight 803 lbs
Ground Clearance 5.6 in
GVWR 1385 lbs
Length 101.7 in
Rake/Trail 25° / 5.2 in
Seat Height 26 in
Wheelbase 67 in
BRAKES
Brake System Type Individual front and rear control with ABS
Front Braking System Dual 300 mm floating rotor with 4-piston calipers
Rear Braking System Single 300 mm floating rotor with 2-piston caliper
WHEELS & TIRES
Front Tire Dunlop® Elite 3, 130/90B16 73H
Front Wheel Cast 16″ x 3.5″ with tire pressure monitoring
Rear Tire Dunlop® Elite 3 180/60R16 80H
Rear Wheel Cast 16″ x 5.0″ with tire pressure monitoring
Tulsa, Oklahoma
Ride Modes
ABS
Keyless ignition
Cooling System Air
SUSPENSION
CHASSIS
Dry Weight 803 lbs
GVWR 1385 lbs
Length 101.7 in
Seat Height 26 in
Wheelbase 67 in
BRAKES
WHEELS & TIRES
