1 - 3 of 3 Posts
Howdy all. I plan on doing a trip, 2 up. How do i set up the rear shock, non air. Is there a table or instructions for sag?
The vintage rear shock is too soft even with the preload on the spring wound up for two up riding, I fitted a rear shock from a Roadmaster/ Chieftan, bolts straight on, has extra travel, and is easy to adjust for 2 up riding, I do a lot of 2 up riding on my Vintage best mod you can do to a Vintage, you could also use the optional Indian lowered air shock, that’s the stock fitment for the 2020 model Vintage, it’s the same length as the original non air shock.
1 - 3 of 3 Posts
