1 - 7 of 7 Posts
I have the Indian ones still, not upgraded yet.
But would assume to keep like the rest @ 4 Ohm
I've swapped out the front and kept them at 4 ohms but hard to get specific info on the factory amp. Will go with the 2 ohm if amp can handle the draw. Still waiting on reply from factory on the specs but there's usually some really good information on here.
The 2 Ohm will overheat the output transistors on the amp. Stay with the 4 Ohm and play it safe. The factory will not release info for their electronics.
Jeff, you are no longer forced to choose between 2 or 4 ohm for high end speakers.
The "modern interpretation" of what a high end speaker should be has created 3 ohm selections with the attending high end specs (e.g. sensitivity over 90) ..
As a "for instance", check out the Infinity Reference line of speakers..
I swapped them out and they are 4 ohm speakers. I would not go any lower. Dean
Discussion Starter #7
I received the radio specs from Indian and went with the Ki
I went with the Kicker PSC65 (42PSC654) which are 4 ohms. They definitely rock. Thanks to all for the helpful advise.
1 - 7 of 7 Posts
