Can you run the Dynojet Quickshifter if your are flashing with the Power Vision 3 vs using a Power Commander? The install instructions specifically state to wire a module on the Quickshifter to the PC V.
Thx
Thx
Thx
Any idea which kit I would order or should I call Dynojet Monday?The q/s can be used with both the PVCX/PV3 and a PCV, separately or in conjunction as the q/s intersects the injector connection. I have had all 3 on my skoot in the past.
RACNRAY
