I received a Dynojet Quick Shifter for the TS-111 (don't know if they will be offering it for the Scout models, assume they will be).
I've run quick shifters in the past on my Harley's that were setup for racing (and fun). The one model I ran was fairly clunky and hard to adjust. With this in mind, I opened the box hoping it was a better design.....I was very pleased! Very clean design with straight forward installation instructions. The kit consists of:
1- Shift Sensor
1- Shift Rod
1 - Shift Kill Module
1 - Ground Cable
1 - Heim Joint
I will be installing the unit this week and testing it out, it looks like a 30 minute installation with the hardest part being getting to the injector connections. The shift sensor goes in-line with the gear shifter and comes with a replacement shift rod (shorter then OEM) and heim joint. The sensor connects to the shift kill module, which connects in-line to the front and rear fuel injectors.
For those that are not familiar with a quick shifter.....with the quick shifter, you maintain the throttle and bump the gear shifter, the sensor senses this, cuts the injectors for a fraction of a second while the next gear engages. Really makes a big difference in racing and street performance applications...like when you want to beat your buddy.
I will post the installation photos and then the results of my testing under road conditions later this week.
1- Shift Sensor
1- Shift Rod
1 - Ground Cable
1 - Heim Joint
