I'd like to do this,will you feel it break loose? I'm a beginner and my skills are minimal. I just don't want to drill to far. Any more help is appreciated.
You will need a drill, cordless or corded, a 12" extension and a good quality 1 1/4" bi-metal hole saw, I used a LENOX 1-1/4-in Bi-Metal Arbored Hole Saw
Item # 348128
Model # 1772491 from Lowes
You will need to remove the stock mufflers. You can start from either end but the inlet end also has the catalytic converters that must be punched out or hole sawed so that you can gain access to the baffle plug. The cat. conv. is hard so let the hole saw do the work, don't rush it, it will saw through it. Once that is done, saw the baffle plug, then flip the muffler and do the other end baffle plug. Getting the pieces out of the mufflers requires shaking the mufflers, make sure that you get the plugs out. Having someone hold the mufflers upright while you're drilling makes the job easier. It truly not hard or complicated and I guarantee that you will enjoy the new sound. Let me know how you make out on this project.
