1 - 15 of 15 Posts
I recently had Hertz ECX 130.5 speakers installed but found that the bass vibrates significantly. Had to adjust equalizer much lower on bass and volume has to be much lower. I did not have any baffling installed.
Quality of sound is not what I expected. Any thoughts??
Thanks in advance
Wayne
Living the dream!
I wonder if your installer didn't reverse the polarity of the wiring? It is the first thing I check for the symptoms you have mentioned.
Discussion Starter #4
Which wire is positive on the ones coming from the bike
Thanks in advance
Wayne
The Polk MM series are the best bar none I have used. These are not the DB series but the higher end MM series. You can turn the volume to make with zero eq adjustment and the sound is crystal clear and no distortion.
Living the dream!
@streak I just went and pulled off the front fairing for another project, the gray/black is negative, gray is positive. Let me know if I need to take a picture please.
Discussion Starter #8
I GREATLY appreciate that!!!
I have Hertz speakers and they are fantastic. I did pad the inside of the cavity with poly foam to reduce resonance. Check out my YouTube channel
Discussion Starter #14
Last thing I did was add boom mats. With polarity corrected and boom mats installed I am extremely pleased. It isn’t quite as crisp as stereo on my last ultra but I had also put well over $1500 into that one. This upgrade was around $150 for speakers and boom mats. I’m very happy!
Living the dream!
I found some 'knock off" DynaMat on Amoz as well as the Hertz speakers. Think I am going to have to go ahead and do this one on both the front, and the back pair.
1 - 15 of 15 Posts
