Shop our large selection of 2020 Indian CHALLENGER DARK HORSE (N20LCDRR) OEM Parts, original equipment manufacturer parts and more online or call at 877-999-5686
What's the trick to remove headlight bezel?
Owner's manual says to pry from top.?..but.?..the parts list diagram shows clip on the side??
Want to remove to paint.... but don't want to break mounting clip.
The piece around the headlight you pry down from the top, then pull it forward. The outer pieces around the turn signals you have to remove the fairing and unbolt them from the inside.
Your best bet is get a set of plastic trim tools, cheap on amz/ebay..harbor freight,
Anyways..pry down from to, a bit stiff but works, there are also clips on side that pop off as you pry down.
