2018 Roadmaster 111cu
Fuelmoto flash that I recently received works fantastic, expect after the bike has warmed up the idle is 750-800rpm. Shouldn't it be higher ?
750-800 is ideal. The original flashes that Fuel Moto put out to help with surging on the decel had an idle of about 1000 RPMs. Many people thought that was too high and many of their tunes dropped it back to the 750-800 range. CraigB did my tune and added a fast idle feature to help the bike warm up quicker. It is about 1250 RPMs till it warms up then slowly drops down to the 750-800 range. Works great. Dean
It should run at a higher RPM when cold and first started.Then,as the motor warms up,the RPM should slowly drop down to the 750 rpm which is your normal idle.
I errored in my above post cause the 750-800 rpm is the CORRECT IDLING rpm on the factory stock machines as well ounce up to operating temperature.DUH!!!
