Yes, I should have added I was hoping to keep the angle as is but I may not have a choice.You can also adjust the angle of the floorboards. Loosen the bolt, adjust the angle, and tighten.
Yeah those mini’s don’t work well up front.. take um off put um on the passenger mounts. Then buy the OEM Boards and fit them to the front. Boards and raising the shifter go Hand and hand.I installed the Kuryakyn mini floorboards on my Bobber today and now I’m having a bit of trouble getting my boot under the shifter to upshift. Anyone else encounter this?
Sent from my iPhone using Tapatalk Pro
Haha. What is that for? And is it like $100?I do see something that both CAL and joyrider need on their scoots.
The Kuryakyn coolant hose cover.
You KNOW you want it.
It cleans up the coolant hose area IMO. Looks better. More finished. Look at my pictures and see if you agree.Haha. What is that for? And is it like $100?
I DO! ... and it's on my list to do eventuallyI do see something that both CAL and joyrider need on their scoots.
Had the same problem and the smarty pants I am (or better: I thought I was) adjusted the shift rod out until it worked. Geared up and got off on a test ride, just out my driveway and .........kind of immediately turned around. Couldn't upshift anymore, not even to neutral
. My solution (since I liked that steeper angle): I ordered and installed the AeroMach heel-toe shifter. Works like a champ and didn't limit or reduce the lean angle like a lowered floorboard would
Nice. Very nice.I went this route and installed it today. It works absolutely perfectly; couldn’t be happier.
Thanks for the tip, @Tabernash! I went with chrome cuz...chrome.I do see something that both CAL and joyrider need on their scoots.
