seems I missed this one. Yes, the PVCX can be used easily without the factory closed loop operation ... in open loop all the time. The ECU runs in closed loop everywhere where the Main Target AFR table carries 14.7 cell values.
So ... putting e.g. 13.8 into all those cells forces the ECU out of closed loop (ignoring the stock narrowband O2 readings). BUT:
To do that a clear warning has to be issued:
- you risk running your engine with completely wrong fuelling which can range from overly rich in the 11s to far to lean in the 16s plus). During our tuning sessions we have witnessed the factory preset VE table being not so accurate in all those areas where closed loop (dynamic correction through O2 sensor data) was expected before! In other words: You need at least wide band O2s and a WBCX to MONITOR and dial in the fuelling. I would never run my skoot blindly in open loop.
- despite having eventually eliminated closed loop operation of the ECU ... you would still need the eliminator plugs (or the factory narrowband sensors still plugged into the harness) to avoid CELs. The VCM/ECU on startup do all kinds of checks on the status of sensors, and the eliminator plugs help fooling the ECU in this regard.
- your fuel economy in "open loop all the time" will never be the same as with wisely preset closed loop areas
- There is no power benefit in running COMPLETELY in open loop with AFRs below 14.7. You can set the idle to low load cruise ranges to closed loop 14.7 (saving fuel) and as soon you slightly twist that throttle your operation jumps to the the higher load open loop areas (where you gave some more fuel).
The only reason I am running completely in open loop is because I came off a PCV (comes with the eliminator plugs!) with dual channel AutoTune (comes with wide band O2s). I ditched the factory narrow bands a couple of years back and welded the 18mm wide band bungs at exactly the same position.
BEST is you have both: the stock narrowbands in place (to selectively keep closed loop in certain areas) and the added benefit of wide bands (WBCX) to do the right tuning tuning for the other areas! (plus there are some more advantages of the narrow bands during tuning ...)
BTW: The PCV is cheating. While the ECU thinks it is in closed loop it actually is NOT. The eliminator plugs do not only avoid tripping CELs but provide constant/same readings all the time. So ... having your PCV tune correct (not only on WOT) is critical for the sane operation of your beloved engine! (Depends on the dynotime the operator invests to cover all areas, not only the areas for the nice peak numbers run!)
