1 - 4 of 4 Posts
Hey all, if I may request some help today. If someone knows where the ntouch radio module is located on a 2014 chieftain... and how to get to it. I have the front somewhat removed and the instrument cluster and can’t figure out where it is..
I believe you have to pull off the outer fairing shell to get to it from behind.
Thanks, I followed the antenna wire to a thin , couple inch thick plastic box. It’s attached to the underside of the windshield motor and metal frame that holds the motor.... scratching my head now about what next; really don’t want to mess with the windshield motor. Getting complicated.
1 - 4 of 4 Posts
