no instrument panel . Nothing lights up completely blackWhat is your instrument panel showing you for a battery charge rate.Mine usually shows a reading of 14.4 or better at idle and when goin down the road.If you're not seeing that,then something is wrong,like a poor or dirty connection at the battery terminals,a faulty battery,or a draw on the electrical system when the machine is parked and you don't know about!!
Battery is age of bike; got it September 2016 but its a 2017 right out of boxIf by "no power at all" you mean, you are not even getting the instrument panel to light up, then battery. If instrument cluster lights up, read the above post. Or change battery in fob or check your tender. Also, you don't mention age of battery, it may be pooched too.
Batteries on bikes take a beating from heat and vibration. Add to that all the stuff they are powering on modern bikes. I replace mine annually as part of routine PM. Put the used ones in the lawnmower. FWIW I’ve had them fail in less than 1 year.thanks for sharing. Most likely a battery. Thought it may last longer then 3 + years
Wow never heard this before. Im used to much longer. But sounds like its the battery.Batteries on bikes take a beating from heat and vibration. Add to that all the stuff they are powering on modern bikes. I replace mine annually as part of routine PM. Put the used ones in the lawnmower. FWIW I’ve had them fail in less than 1 year.
There was a battery drain issue on some early bikes. It was caused by the dash being powered but no lights showing, a kind of sleep mode. It was caused by shutting down the bike, but then operating the saddlebag locks with the fob. This woke up the internals of the bike but didn't show lights on the dash. Once half awake it wouldn't turn back off. A new flash to the computer fixed it.I seem to remember there was a part that needed to be replaced on the pre 2018 bikes for killing batteries prematurely. Don't remember if it was done as a recall or not though. Might want to look it up. I could be thinking of something completely different though :/
It's something I read last year when reading a post about replacement batteries I think. Again, I may be way off about it.
I agree thanksI just checked my records and the battery in my old Harley Shovelhead is going into its' sixth season. I think I bought it at Tractor Supply for about 40 bucks and didn't expect it to last through the ride home. I simply don't think there is any rhyme or reason to this stuff anymore. Ken
thanksThe rule on a motorcycle battery is that if you take it out, bring it inside, keep it beside your bed and pet and charge it daily all winter, it will last about two years. If you leave the dern thing outside in the snow and rain and pee on it every day all year long it will last about two years.
Just kidding. I have had several battery tenders show everything is fine and battery won't even turn on a courtesy light. I had the one in my Corvette puke out just last week. I had a Schumaker tender on it and it had the pretty little green light on and everything. I now hold the drop-kick record for a battery tender. I bought four battery tender juniors on ebay and had one of them bad out of the plastic. Luckily, I have a full size charger that will a battery up to snuff pretty quick. The bad thing is once a battery is totally flat, it cuts its life down pretty significantly. Ken
I did and still went dead.A lot of times,the battery will go down from lack of use.If that's the case here,use a battery tender connected to the little pig tail under the side cover to keep it charged when not in use.
