New soon to be released DynoJet Invision for PP108'S
8.6K views 43 replies 20 participants last post by  Moe1962
I have been blessed with a long standing relationship with DynoJet, having been a DynoJet Dyno owner/operator for 25 years along with selling/installing their Jet Kits since the early 80's, and I also go all the way back to be a beta tester for the original Power commander on my 1997 TL1000S. Add the tuning of their products spells a long successful history.
Add onto that a person (who shall remain anonymous unless they chime in) has even deeper connections to DynoJet than I do and has alerted me to some of the goings on thru the years.I found out about this Invision system coming soon so let me explain what I know, and remember!
The Invision is a specially programmed PV3 that connects to the skoots diagnostic port that has all the same abilities to see what is in the ECU, plus what info is going in and coming out. Also the ability to clear fault codes and very importantly perform DATA LOGGING. Viewing real time data on the PV3 screen is a nice feature.
At this time the ability to store maps and flash the ECU is being worked on and will be available in the future. In the future there will be a provision to purchase a license to allow tuning of the MG1 ECU with this device.
I have been workin on my skoot for a few weeks to add on the ability for this Invision to monitor and be able to see in logs ACTUAL air fuel ratio thru my dual band WBCX. I bought a take-off front header and modified it with wide band bungs for the wide band sensors needed to see AFR. I have had a PCV on my skoot for some time and did some FI tuning but I was SO in the dark with the actual needs of the engine. Having wide band sensors in my dyno tuning days absolutely spoiled me,and werking with the wide bans on my Chieftain years ago helped that skoot be a very good running skoot. Now I can refine my AFR over my seat of the pants, look at plug color has done.
This is a step in the right direction for performance minded peeps. Their is the opportunity thru logging and supplying logs to any of the FI tuning entities that offer tunes for the PP108 for further refinement of that tune.
The released date may be in Early Jan 2024, when I hear a date I will let u'all know.
Right now I have 2 screens populated actively showing RPM and TPS, here's a pic of TPS and RPM and my wide band install on the header. Got some bugs D/J has to work out so I can see AFR, but thats what I'm here to help with.
RACNRAY
#42 ·
Tonite's ride was quite entertaining watching the screen. Some areas not too far off, with AFR for the 2 cyl's close also. Gettin into the big throttle openings and high rpm skoot is purty rich with quite a bit of difference in AFR between the 2 cyl's. Did bout 5 logs so eager to take a looksee 2morrow.
Getting the idle AFR to my liking gave the skoot a cool raspy sound!
