1 - 20 of 82 Posts
Service Advisory ISA-20-01 Released
02-06-2020
Indian Motorcycle has developed an updated ECU calibration for 2019 FTR1200 motorcycles which reduces the occurrence of false-positive throttle plausibility faults (P1530), traction control calibration improvements, and shortens engine warm-up time to improve cold start performance.
02-06-2020
Wow finally!!!! Where does this show? Checked Indian and Polaris websites.
There's an asterisk that says due to regional emissions requirements it's only available for North America and Region at this time.
I've made an appointment with my dealer to have my ECU upated this Saturday!
Maybe there's some magic involved sending your new PV_INFO to your tuner to get your existing maps to work?
I bet it's going to be ok in the end.
Right but after that will it flash onto the Dynojet or you are always stuck with the stock tune file?
Should be no different in that respect to the original stock file, like Max implied you didn't load that from your PV3.
So I would put the stock map back in and take it to the dealer. They'll load up the new one then you can go home and change it back. I'm thinking you'll end up with two stock files to compare?
1 - 20 of 82 Posts
