1 - 5 of 5 Posts
Trask Powerflow Intake Filter for New Indian Scout
This new TRASK POWERFLOW filter product is designed as a direct bolt in replacement for the very restrictive stock OEM Indian Scout air-box and filter.
The TRASK POWERFLOW filter greatly improves both the airflow and volumetric efficiency of the Indian Scout’s engine, by allowing it to scavenge as much air as possible to fill the cylinders.
Dyno developed and Dyno tested, this TRASK POWERFLOW filter will provide the Indian Scout an instant increase of up to seven additional horsepower and torque in the powerband, with no additional mapping or re-mapping required.
Made from only the best materials, consisting of high quality pliable rubber, four to six layers of cotton gauze, and epoxy-coated wire mesh, TRASK POWERFLOW filters are both durable, washable, and reusable.
TRASK POWERFLOW filters are designed to provide your motorcycle engine with excellent protection, that is made to last, while saving you money, and increasing your horsepower.
Thats an impressive chart! Do you happen to know what pipes were on the above referenced bike?? Thanks JJ
Distinguished Founding Member
That's Basically what I gained was around 7 on the Dyno Highly recommend this Filter .. Although that particular dyno is optimistic or that Scout must have some awesome pipes to get 92.8 HP before the filter but my Gain is around the same anyway, which is what counts ..
1 - 5 of 5 Posts
