Well it took a year but I broke down and replaced the clutch cable and installed the Barnett clutch arm.. what a pain in the ass. Why in the hell would they run the cable between the engine and frame tube. You nearly have to remove the left side down tube.
I liked the quality of the Barnett cable EXCEPT they do not install a rubber bellow on the end of the cable to keep out water and dirt. Piss poor decision if you ask me as the end of the cable points up and out so it is waiting to fill with water if you are in the rain or wash your bike.. I cut the old cable and got the bellow off and using a lot of lube and prayerful stretching got it over the barrel on the new one. It does not seal tight on the cable case like the oem but it’s better than nothing. I called Barnett and they had no idea why their engineer didn’t add one. Without it the bottom will fill with water and eventually cause a failure...
The clutch arm install sucks as no one can tell you how to index it on the shaft. Barnett says to install it like the old one.. one problem, this one is not shaped like the old one and the manual says it should be a 60 degree angle with the case looking up from the bottom... ugh.. It’s on and adjusted so we will see.
mark
mark
