1 - 5 of 5 Posts
2016 Springfield . I put Chief Nata Cha into first gear hot or cold. It clunks like it goes into first gear but stays in neutral. Clutch cable adjusted. New Indian oil change kit . Good oil level. If I mind what I'm doin its OK.
Adjust the pedal, there's an adjustment in the rod under the footboard. Raise the pedal up a tiny bit.
Its a common thing my roadmaster does that every now and then at stop lights just tap a couple times to make sure your in gear but I totally get what you're saying,if I know the light isn't going to be to long I just hold the clutch in till its go time.
Sent from my LGMP260 using Tapatalk
1 - 5 of 5 Posts
