Ok got the new bars used Roxy riser to get the 2"pull back and indian mid ride bars. I like the set up but the controls are out of place. They tilt forward. I was told there's a pin on the bars to prevent adjustment. And the bars can only pull back so far because of tank clearance. Does this all make sense... rode better then stock but my right wrist went numb due to angle of grip.
Is there a fix
Which controls? The switch housings or the levers? As stated above, the switch housings have a pin that holds them in place. The levers can be moved by loosening the clamps and rotating them to where you want.
So far as moving the bars up and down, you have two pivot points with the Rox Risers: one pivot point where the risers connect to the stock clamp, and one pivot point where the bars connect to the Rox Risers. There is not much room to move the Rox Risers around, due to limited clearance between the fairing and the tank. If you have the stock console on the tank, you should have plenty of room to pivot the bars down to a comfortable angle. If you have the gauge cluster console (from the Elite) installed, there is less room, but you should still be able to bring the bars down 3 or 4 inches from "all the way up" before you contact the console when the front wheel is turned.
