Check battery connections.
It is the bulb. Change it and you'll be fine. Consider going to an LED in the long term and you'll not have to deal with it again.Getting ready for a ride and headlight wont come on. The high beam indicator light is blinking on and off, driving lights are on and wont turn off. Is there a fuse somewhere? I checked the ones under left side cover, none blown. HELP!!!
Agree......I was at Sloan's in Murfreesboro TN some months back and there was a guy that while on his way to a sidecar rally had the same things going on with his Classic. It turned out to be a bulb and they had him back on the road in about an hour.The almighty Google leads to info that the headlight bulb is blown. Probably both beam levels. Others have reported it before.
It is indeed the headlight bulb, have had to change mine out twice. Blinking hi/lo indicator is meant to alert you that your bulb isn't working. You would never know it till the sun went down if you were running alone. As to why it would take an hour to change out - on a Chief you must take the nacelle off the bike to access the bulb. One of the few things about my Vintage that sucks - DanI can change the headlight bulb in a RM/ Chieftain in about 10 minutes. Why would it take anyone an hour?
The whole headlight assembly (nacelle) must be removed from bike to access the headlight bulb on the Chiefs - DanThe RM/Chieftain (which it appears the OP has) takes just a few minutes. Does the headlight not come out of the front easily on the unfaired bikes?
