1 - 13 of 13 Posts
I’ve gutted cat and cut out both the plugs. When I shake the pipe I hear small cat shavings inside the honeycomb holes. If I put these on will they blow out? Will some shavings get sucked into engine?
Thanks
Thanks
Full throttle out the driveway should take care of any shavings:p:p:D
That at least sounds fun for me... not my neighbors I’ve heard some good videos of open pipe stock exhaust
I worried about the same exact thing after I removed the plugs and CAT. 5k miles later my bike is still running as good as new, especially with the FM tune.
Good to hear! Was your bike back firing a bit before the FM tune?
Not once has it backfired after I gutted the CAT and removed the baffles. This is before and after the FM tune...now, I do notice the idle is sometimes a little erratic but it's never stalled on me. I don't know if that has to do with the tune/exhaust mod or this is common with the S60's. I've read a few other people having this problem with bone stock Scout 60's and non-modified exhausts, so I'm thinking it's just the nature of the motor.
Discussion Starter #8
It seems to sound really good though, at least through the videos.
Thanks
Thanks
It sounds surprisingly good given that it’s still technically the stock exhaust. I seriously considered slip on’s but IMO the stock pipes look a lot better. After the FM tune and CAT/baffle removal, I really have no need. It’s not obnoxiously loud (it sounds awesome when you give it throttle) but also no longer sounds like a sewing machine.
rshea,,
If you ever want to go back to "stock", I've got two sets of muffler that are unmolested that I'll sell cheap.
Good luck
I may be wrong but it seems that if your bike is running the way it should and you have no valve damage, you will be fine. Very little chance of a cylinder sucking debris out of the exhaust.
Reactions: MOMZ
Discussion Starter #12
rshea,,
Good luck
I’m actually running stage one indian slip ons now, and have thought about no cat and plug on those too. I want a bit more sound. I’ll have to experiment with both sets maybe. But my stock is ready to give it a go... just for kicks!
Thanks for the help
1 - 13 of 13 Posts
