2014 Vintage, somehow I have lost this screw and the underneath plastic washer from the back fender for the seat/rack. Anyone know the specific size please? Thanks in advance!
Blue Loctite and only very moderate torque required - I would go with 10-15 ft.lbs. max. Nothing critical there except for keeping the bolt on the bike.Torque values, too?! (sorry, it fell out; so did mine one time!)
Appreciate you sir!M8 x 1.25 thread pitch.
Hell no. If your battery quits on the road good luck getting the seat off to access the battery.Blue Loctite and only very moderate torque required - I would go with 10-15 ft.lbs. max. Nothing critical there except for keeping the bolt on the bike.
Good point, except no problem if you are also carrying the right tools. Perhaps this is why some folks have lost that fastener.Hell no. If your battery quits on the road good luck getting the seat off to access the battery.
Hand tighten the Indian OEM seat bolt. Use a small crescent wrench to gently loosen.
https://www.indianmotorcycle.com/en-us/shop/accessories/decorative-hardware/2881187/
Something that I am not near as good about as I should be. I carry a aluminum set of allen keys and an adjustable wrench which might not be enough.Good point, except no problem if you are also carrying the right tools. Perhaps this is why some folks have lost that fastener.
