Lowering links for Indian Roadmaster/Chieftain
118 views 4 replies 5 participants last post by  therev
This has probably been asked before, sorry for the repeat.
Anyone installed lowering links??
Do you need to remove rear fender?
Like, dislike, changed back to stock?
Thanks for your time
#2 ·
Shameless promotion. I've had both. Don't bother. Install a fox lowering shock. Far superior ride , same travel, 1" lower. I have one barely used for sale in the classifieds for more than half off. Good luck with your decision.
#3 ·
I had the 1.5" links installed. I ended up going back to stock after I swapped my header pipe to a Rush H.O. and scraped the header on the pavement. Prior to that, I was dragging my exhaust pipes all the time during spirited riding.
#4 ·
Changing out the lowering gusset is a pain, removed batt, batt. Box, rear fender, shock. Not terribly difficult just tedious and time consuming. But yes after I scraped my Khrome Weks 4.5when I turn corner. Good luck.
