1 - 15 of 15 Posts
Anyone else notice a surge,like a blip of the throttle, when slowing to stop? Happens around 1100 every time I slow or drive easy for a maneuver. is a bit of a pain as you need to hold the clutch in early coming to stop sign. Dealer said normal, drive by wire symptom.
Thanks.
Limited Edition - Solid Red Roadmaster
yep - all the TS111's do that
I just avoid the deceleration under load (clutch in and brake) when I get that slow because that 'Low RPM surge' is annoying
Read Only
Annoying yes, normal yes, it's Indian way of limiting low speed lugging with closed throttle and also avoids stalling the motor. You'll get used to it. It takes time, but you'll get used to it.
Thanks.
yep
Thanks.
Yes, there is a table in the ECU called Idle 3d table that controls at what idle RPM will be based on gear and vehicle speed.
Here is the table showing the factory stock values. You can see the 1100 RPM in the table. Some folks here (me included) have modified this table to minimize this "surge" by lowering the RPM down to 800 sooner. This makes for a more predictable deceleration response.
This table is accessed using Dynojet's Power Core Software and their PVCX flash tuner.
Text Font Software Screenshot Line
I adapted to it and subconsciously avoid it with technique. I can't remember the last time it surged.
Banned
Mine has always done this. It has never bothered me. I personally don't find it annoying. I just pull in the clutch and avoid it. Sometimes I just let it do it. But it's definitely normal for TS111s.
Thanks.
You need to stop going so slow.
Texas Hill Country
Big Daddy Enterprises Titanium Boot Taps only $79.95.
When you feel that sickening lurch and lunge of that Big Indian it's just telling you that it's time to impress your friends with a spark shower.
Drop your boots to the ground and let them bitc#es eat.
Grind to a stop in an impressive show of class.
Last year's ECU re-flash seemed to improve low speed running significantly, along with fuel consumption. Mildly irritating, I agree. Just counter it by trying not to slow down too much...
Discussion Starter · #13 ·
Ha! I will put the motocross boots on and drag the toes for sparks. Parking lots and Lights are the only time I do notice this...wife thinks I forgot how to ride.
Did you have to adjust for this on your own or do you know if Fuel Moto already accommodates for this in their PVCX tunes?
On your own, unless you specify to FM you want this. Best to my knowledge, FM does not change this table in their tunes.
As a side note, it was only recently Dynojet exposed the Idle tables, in large part for FM to be able to tune these new cams coming out.
1 - 15 of 15 Posts
