If I look in my right rear view mirror I think I'm on a Harley. Let's start with the pieces. There's the "arm", the "mount", the "mirror body" and the glass. From the handle bar through the mount, which connects the arm to the mirror body, all is well and tight. The looseness is between the mount and the mirror body. The construction leads one to believe there is a fastener between the inside of the mirror body and the mount which has loosened.
The mirror glass is surrounded by a rubber seal which holds it in the mirror body. It appears to me that if I could get that seal out, I should be able to get inside and tighten the fastener which connects the body to the mount. My dealership doesn't know what's behind the glass or how the mount and body are connected, and their on-line parts breakdown doesn't breakdown that far.
Has anyone had this loose mirror problem? Has anyone seen a broken mirror glass and seen what's behind the glass? I hesitate to try to pull out the seal to remove the glass without an idea of what I'm in for.
Thanks for any info you may have.
