Thanks. Been looking at backside but can’t figure which parts to remove to get it looseJust a couple of screws inside the tub, lock cylinder will rotate and then slide out of the mechanism after the bracket is loose. Only minimal dismantling required to pull the cylinder.
Hiding something from the misses?Thanks. Been looking at backside but can’t figure which parts to remove to get it loose
