Do you think the improvement you had with the 585's worth the cost? Did you replace the clutch with a heavy duty?
Thanks,
Yes, had to upgrade the clutch. Slipping at will in 6th ...
I put the Barnett Extra kit in.
Worth it? YES ... baddest 111 around. Smoking 110 CVOs (with stage 1 and tune) and easily keeping up with 114 M8s with stage 1 and with TS116 factory setups. (still my top speed is limiter disabled ... so passing them eventually)
TS111 in stage 1 and stage 2 config have no chance.
Only minor (in my ears) downside: You can hear "a big cam valve train" at idle.
While riding no abnormal noise (too busy with enjoying anyway).
