1 - 2 of 2 Posts
I own a 2015 RM, over the last month I've had the Instrument pnl "idiot lights" light up all at once, gear indicator out and once in a while the tach will bounce around. Now so far this has only occurred in the morning usually about 25 min into my ride to work. once I shut off the bike and restart all goes back to normal. Has any of you run into this issue???
Check your battery connections and frame ground. My 2015 RM would do the same and found the positive battery cable was lose.
1 - 2 of 2 Posts
