I'm wondering what kind of lift you guys are using. Being I'm a vertically challenged individual, I put a bestway lift "in" the floor of my garage so I could drive the ultra over it & raise it; rotate it 180 & I would heading in the right direction the next time I rode. Well this roadmaster does not have any frame under it, I'm kind of hesitant to raise & lower it just by the motor itself. The book says it's OK, just supposed to have a minimum of 12x12 square under it when you raise it. I have built a small platform & put rubber on top of it to put between the lift & the motor bottom & that works but I still have to cinch it down pretty good for stability. I was wondering if anybody might have the same situation & what kind of solution you came up with.
Thanks.
Thanks.
