We went to the NYC motorcycle show this past weekend and while cruising the wares I found this:
AdMore Lighting High Output Premium LED Light Bar | Running, Brake, Progressive Turn Signals & Smart Brake Technology | TwistedThrottle.com
"Significantly reduce the risk of a rear-end collision with a sophisticated accelerometer that activates brake lights with no input other than rapid deceleration via throttle release or downshifting. Command attention with 81 retina burning LED's that feature progressive amber turn signals. The brake light ignites with a flashing strobe upon initial application to capture the awareness of drivers behind you with a consistent strobe of white LED's that are sure to be seen. The unit also works with the hazard (4-way flasher) lights of your motorcycle by activating both progressive turn signals to increase roadside visibility.
This LED light bar is pre-configured with the most popular settings and options, and is primed to go out of the box. If you like to tinker, and tweak, the AdMore light bar allows you to customize its pre-set status. Simply connect it to any computer using the included Micro-USB cable, and the
AdMore Configurator Software Suite helps you modify the brightness level, deceleration sensitivity, brake light modulation, white strobe light, license plate light and more!"
The demo REALLY CAUGHTR MY EYE", so I'm hoping it'll have the same effect on the cage drivers behind me. Totally programmable with the laptop 'puter, it does running lights, brake lights, signals, etc. I whipped out the credit card and, 3 days later, it's here. Unfortunately Santa is holding the unit until Christmas morning. When I have more info I'll post it, but it sure looks like a perfect fit for the spot below the Roadmaster's trunk.
