1 - 12 of 12 Posts
I have some kst handlebars I'm looking to install. Does anyone have any knowledge of the cost to have those installed at a dealer? Or should I just do it myself? I've done handlebars on my old cross country but that wasn't near as expensive of a bike and makes me a little more nervous to tear apart..
Sent from my Pixel 2 using Tapatalk
Hey there,
Installed the KST Apache Bars (+6") myself on my 2019 Chieftain. Isn´t that difficult. Only tricky thing is to get the connectors thru the bar on the throttle side. Brake line and clutch cable are long enough but you will have to run them a little bit different.
Took me about 5 hours from start to end.
I can recommand the change, more comfort and better look!
Regrads Markus
I asked my dealer about the install, as I am looking at the same bars for my Roadmaster, and I was told $300.00 in labor.
My dealer quoted a handlebar installation at 3 hours of labor, which, at my dealer’s shop rate of $110 per hour, would come in at $330 before tax.
I did it myself as well...not hard at all...just time consuming...put the heated grips on as well...plug and play...save urself the money...and with the money u save u can buy more stuff to install...lol...
Discussion Starter #8
Yeah I'm just gonna do it myself... It's a long winter here and I should have plenty of time..
Thanks everybody!
Discussion Starter #10
All the bikes on this thread are sick..
Really love that black dark horse!
Hey there,
Regrads Markus
How are you doing? Can you give any insight as to what you did to run the wires? I'm in the middle of the installing the same bars and its really kicking my butt.
Thanks
Al
i dropped a small piece of chain to pull the first set of wires thru then the same on the other side...attatching the wires with electrical tape securely and pull them thru very slowly...u can pick up the chain plastic or metal up at Home Depot...i have a set of 16" apes on my other Indian and that wurked perfectly with them...ive had apes on all my bikes and that method wurked the best...
1 - 12 of 12 Posts
