This is a long-standing problem that I'd learned to live with inasmuch as I didn't do anything about it! But I'm in Scotland and we're still on a lockdown and I've done everything I can possibly do in the garage so started looking at other bike-related stuff, so for the first time really I opened the ecu map for a poke about.
Here's the problem - I have a 2014 Chief Vintage with a 116 big bore kit; I've had it since new. The 116 kit wasn't a supported setup in the UK (I bought the parts in the US) so Polaris wouldn't give out a map. I already had a PowerVision fitted as it had Stage 2 cams before that, so had it remapped. It's been running not too badly, but I rode down to Italy last summer and met heat that we just don't get in Scotland (90+ degrees F). If the motor was idling stationary for a few minutes then it would pink/knock something awful trying to pull away unless I used just a hint of throttle. The knock/pinking was so bad I could hardly get over 50mph with the throttle only just open until the motor started to get some cooling off the airflow. So whatever 'knock control' was doing, it wasn't controlling the knock!
Back in our chillier climes it's been fine. but with nothing else to do I opened up the map out of curiosity and I'm seeing a Knock control section. Now there are 2 problems here - first I'm an absolute newbie here with the map and have only just worked out how to navigate it and do comparisons and I certainly don't know what most of the stuff means, and second we don't have the heat here to try it out! But I do plan to ride down to the Spain or the South of France once we can ride again so if there's any change I could make now in advance that would be useful.
But after that - maybe I'm now being paranoid - I think I'm feeling (or was feeling...last time I rode!) a very slight knock sometimes at about 2800rpm moving from about 1/4 throttle to 1/2 throttle, and that's in our cooler weather.
Doing a comparison it appears the current map in this area is the same as was standard (for a 2014 111) - no changes to Knock control were made with the 116. Happy to post up pics of various sections of the map if anyone's got any ideas and wants to see something.
Probably not related, but I've always had an issue that if I'm decelerating on a closed throttle and then blip the throttle for a down-change it occasionally spits back through the filter, doesn't lift the revs and sometimes actually dies. Is there another part of the map that controls this, and what might I experiment with? Now this I can test here...but once we're riding again.
Thanks
Thanks
