1 - 3 of 3 Posts
Anyone install these on a 17 Chieftain? Did you need to change the clutch cable and brake line? The Indian mid rise doesn’t require the replacement according to the website. The Ergo bars appear to be lower that the Indians bars so not sure why I would have to replace them on the Ergo and no the Indian. Ergo bars come with cable and brake line. Any input appreciated. Thanks
They might have more pullback, so that might require longer cables. However, depending on how the cables are routed, you can sometimes get away with rerouting the stock cables.
The brake line goes all the way back to anti lock block of lines and Im cool doing it. Not sure if it requires more than just bleeding the system or if more is required. Could probably call a service department on that. Thanks
1 - 3 of 3 Posts
