1 - 3 of 3 Posts
Got my new jack in. Instructions as to where to put the jack under the bike aren't too clear... I have the Indian adapters.
It says put the rear bar "in between" the drain plugs....they are practically 1/2" apart from each other, so this isn't possible. Does it mean behind the drain plugs?
It says for the front, to place the lifting arm right behind the kickstand. Does that mean on the front lower frame tube, or on the front of the engine case?
Sorry if these are dumb questions (and there ARE dumb questions!), but I just want to do it correctly and not mess anything up!
Thanks
Place the rear pads just back of the two drain plugs. That will place the front pads right on the front frame tubes.
T
Thanks
1 - 3 of 3 Posts
