1 - 7 of 7 Posts
2019 Bobber - Can't find this particular part pointed out in the manual however my Google searching seems to indicate that it's a thermostat cover. Just to be sure - this IS the thermo cover right? Ultimately I would like to change the stator cover, ignition cover, and this cover, however I can't seem to find a thermostat cover that fits. Any ideas?
574362
Yes, as I recall you would need the other Scout mounting bracket for cover.
That underlying bracket is different somehow.
Both of the covers on the Bobber can be replaced with the scout '60' covers.
you will need to order the right side bracket :
BRACKET-THERMOSTAT,RH Part # 5260093
And the thermostat cover :
COVER-THERMOSTAT,RH,BLK part # 5633371-266
Same goes for the ignition side.
BRACKET-IGNITION,LH Part # 5260114
COVER-IGNITION,LH,N,BLK Part # 5633064-266
All the part #'s you need are on this link.
@daveholl Hey Dave, where did you find the accent on the radiator? I've been trying to find one since I saw it on an image from a guy in Brazil!
Sent from my SM-G973U using Tapatalk
1 - 7 of 7 Posts
