21 - 29 of 29 Posts
2020 Indian Challenger Base
Bear with me here and forgive me for not tracking. What part of the trunk are you resting on the rear spools? The rear attachment points?
You get the front fully seated, then the rear is sitting on the rear spools. Just push down, and you will hear (clunk) it seat. There really is no mystery to it.
The bottom of the trunk mount has two curved "bars" running between the front and back attachment points. I set them on the rear spools, then slide the trunk forward (lifting the rear) until the front attachment points lock in on the front spools. Then push down to lock the rear attachment points.
Reactions: Gearset807
I have found that if I open the saddle bag lids, grab hold of the passenger armrest bars, I can usually get it mounted on my own. If I feel I need to set it down, or loose a grip, not going to hurt anything with the lids out of the way. I am 6ft. tall, so can usually look around the side while holding the trunk, so that I can line up the front latch on the spools. So it may be easier if you have the factory passenger armrests in place.
I'd be careful using the passenger armrest bars...the moving company managed to bend mine while using them to push the bike into the shipping crate.
Taking it off is easy, although heavy. I just kept the locking bolts out to not have to remove the saddle bags. So far I've always put it back on myself, but it is very awkward. I get the front on, then wiggle it down into place. I did spliter/break my antenna last time I reinstalled, so caution. :(
You can remove the seat without removing the trunk. You just need to remove the charging port and use a long allen wrench to get to the bolt for the seat through the hole for the port.
Get a thumb screw for the seat bolt. Don't mess around with a long allen wrench...
Rest the trunk mount on the rear spools, then lift and slide forward to engage the front spools. Then, move to the rear of the trunk and push down to engage the rear spools.
Yes, this. Been doing mine this way for 5 seasons.
67 years old and I remove and reinstall mine multiple times. Not an issue just a bit heavy. Remove the saddle bags and you will have more room. Take your time.
I was thinking about doing a pulley system to remove the trunk by myself since there are times I want to ride by myself. Tried to do it without the help from the wife and gave up. It’s not worth damaging the trunk or saddle bags or both. I take my time and remove the saddle bags and what else is in the way to make the job easier. These are expensive toys and not worth taking a chance.
21 - 29 of 29 Posts
