41 - 60 of 130 Posts
View attachment 462200 Before is only the 5.75” holegen headlight.. this is after...
Is that Schofield in the background?
Also- You wrote about the DH rear conversion. Can you please do a write up for your running lights, the module your getting to make the rear turns also brake, and the other lighting things you've done? A lot of what you've done is what I want to do.
Hey ScotD, I will try.. Not Scholfield, but I do live Mililani Mauka, 5min away... My latest... I removed the small Rear LED’s and added two larger rear blinkers from a 2019 Dark Horse... I had to swap the connectors from scout to dark horse blinkers... Scout is female and dark horse are male... Snip snip, solder solder, heat shrink and here they are... They are bigger and so much brighter...
The lens are not shattered, that’s all LED’s....
I removed the OEM blinkers. There is a Allen bolt to in screw. Much easier if you have the long rounded allen with 3/8 drive extension.. that way you can be on right side to unscrew the left side and vice a versa..
I used a longer 5/16” bolt with 3/4” spacer, flat and lock washers...When you remove the OEM blinkers you will see three hole on the bracket. I used the middle to allow the cable to use the larger hole. Tightened bolt. Ran the cable through and plugged them in... No idiot light on speedo. Might be because am running LED bulbs for front blinkers... Time was used mostly to solder... Bolt/washers I got from Home Depot.. do not need to use spacer. And you can bolt to fender.. I chose exisiting holes.
Hope no one is offended with the eyes on the sculls... Not sure why I went with 2019 Dark Horse blinkers. I imagine there are other bikes with same type blinkers... OEM Dark Horse blinkers run about $120.00.. I got mine off of eBay for $80.00...
Victor s. Rod. I no longer have the LED bulbs in the rear. I changed the entire rear blinker assembly to the Dark Horse Blinkers... Posted photos above. and posted how I did it...
@mbrownp1: Any error code from the LED indicators?
As to the official Indian Scout LED headlight; Somehow it looks more appropriate on the FTR...
I’m not sure why everyone is spending so much money on this. I got the lamp below for $48. Bright as hell and no probs after 6 months so far.
Same one I have on my Dyna .. Has Lasted 2 Years and 20,000+ Miles ..
I always say: If You are happy with what You bought at the price You bought it for. No worries... If you are looking for a deal, You will find it.. But even then, someone will have bought the same for less and/or for more...
I used a longer 5/16” bolt with 3/4” spacer, flat and lock washers...When you remove the OEM blinkers you will see three hole on the bracket. I used the middle to allow the cable to use the larger hole. Tightened bolt. Ran the cable through and plugged them in... No idiot light on speedo. Might be because am running LED bulbs for front blinkers... Time was used mostly to solder... Bolt/washers I got from Home Depot.. do not need to use spacer. And you can bolt to fender.. I chose existing holes.
That's an awesome mod! The red eyes are both cool and amusing. It's your bike and you only need make you happy kaikaina. I remember Mililani town. I kept my mouth shut and head level and smile on my face.and kanaka ok with me.
I’ve been staring at the Scout Pathfinder light in my cart for 4 days now. Can’t pull the trigger on a $300 light, though I do want it for the Indian branded half halo LED
I've had a 7" Trucklite LED headlight and Dietz headlight bucket I have yet to fit. I'll be making a mount that uses the existing mount so the OEM windshield will still fit.
I chose this combo so it retains some of the retro look over the LED- eyeball style.
Well, I guess I'm stoopid. I hadn't paid attention to the "on" pics of the FTR to realize the surround of the upper LED units was illuminated. Guess the question is whether I'm stoopid and $300 poorer.
Pretty sure I’m about to just be $300 poorer. Said I wouldn’t be a brand whore, but here we are lol. Especially since I’m one of maybe 2-3 Indians in this whole area.
Ehh be a brand whore I won’t judge lol. I feel your pain I’m about to get 2 of them. One for me and one for the wife. FML
