1 - 7 of 7 Posts
· Vendor
The Lilith Challenger - Custom 2020 Challenger Limited
Size: Covers the full tank side of ALL Indian Scout models
Material: Laminated vinyl decals (either 12 mil gloss or Sandy Matte laminated). Hi-Tack Self-adhesive. Weatherproof and UV resistant, this material will last for many years and not fade. Can be applied directly over existing logos and will not damage your paint. And emblems on the tank would have to be removed before applying the decals (OEM emblems are applied with a double-sided adhesive tape and can be easily removed with dental floss moved back and forth behind the emblem. The remaining adhesive residue will wipe off with Goo-Gone. Clean tank with soap and water afterwards.
How To Install: <-Visit our How To page for videos
We recommend using the wet method to install larger decals: A spray bottle with water and dish soap can be used to wet the tank and the back of the decal, allowing you to slide the decal into place. To get the proper soap/water mix, start with a squirt of soap into your spray bottle. Shake it up and then spray it on your hand. Rub your finger tips together. You should feel the slipperiness of the soap. If it just feels like water, add more soap and try again. We recommend using less "wetness" for application on matte paint since the surface stays moist longer and will make it take longer to adhere. Once you have the decal aligned properly, use a squeegee or some non-abrasive tool (even your fingers) to push the moisture out from behind the decal and it will adhere to your tank. Start at the center of the decal and work outwards so that you can push any moisture and air out from under the decal. A plastic putty scraper with a thin cloth wrapped around it will work great and prevent scratching your decals. A hair dryer can assist in drying up the moisture faster for quicker adhesion.
Altered Carbon -
Hood Automotive tire Automotive design Automotive lighting Grey
American Flag (Color) -
Land vehicle Fuel tank Vehicle Motorcycle Motor vehicle
American Flag (B&W) -
Flag Flag of the united states Sleeve Gesture Automotive design
Bear (B&W) -
Mouth Roar Carnivore Jaw Felidae
Bear (Color) -
Carnivore Felidae Jaw Roar Whiskers
Bolt -
Automotive lighting Automotive design Font Material property Automotive exterior
Bomber -
Tire Wheel Fuel tank Vehicle Automotive fuel system
Dragon Slayer -
Automotive tire Hood Automotive lighting Automotive design Rim
Dragon Warrior (B&W) -
Black Flash photography Eyelash Font Black hair
Dragon Warrior (Color) -
Tire Wheel Land vehicle Fuel tank Vehicle
· Vendor
Discussion Starter · #2 · · Business
Fenrir -
Land vehicle Fuel tank Vehicle Wheel Tire
Herald of Dawn (B&W) -
White Eyelash Organ Black Flash photography
Herald of Dawn (Color) -
Automotive lighting Motor vehicle Vehicle Fuel tank Hood
Honeycomb Sunset -
Organism Font Tints and shades Symmetry Pattern
Mainframe -
Automotive parking light Automotive lighting Hood Automotive tire Automotive design
MesoChief (Color) -
Sleeve Feather Natural material Headgear Art
MesoDancer (B&W) -
Tire Land vehicle Vehicle Fuel tank Wheel
MesoDancer (Color) -
Morganna the Demoness (B&W) -
Photograph Hood Black Aircraft Vehicle
Morganna the Demoness (Color) -
Wheel Tire Fuel tank Vehicle Automotive fuel system
· Vendor
Discussion Starter · #3 · · Business
New Skull Warbonnet (B&W) -
Tire Wheel Land vehicle Fuel tank Motorcycle
New Skull Warbonnet (Color) -
Automotive lighting Automotive tire Hood Motor vehicle Fuel tank
Sunburst (B&W) -
Rectangle Art Font Pattern Automotive design
SWB-729 "Black Lift" -
Vehicle White Motor vehicle Speedometer Automotive tire
SWB-729 "Bronze" -
Fuel tank Vehicle Automotive lighting Automotive tire Wheel
SWB-729 "Chrome" -
Hood Automotive lighting Automotive design Automotive tire Vehicle
SWB-729 "Gold" -
Feather Art Font Wood Event
SWB-729 "White Smoke" -
Flash photography Wood Water Liquid Darkness
The Eagle -
Bird Plant Water Vertebrate Accipitridae
The Hunt (B&W) -
Dog Vehicle Motor vehicle Hood Automotive design
· Vendor
Discussion Starter · #4 · · Business
The Hunt (Color) -
Vehicle Hood Automotive design Carnivore Car
· Vendor
Discussion Starter · #6 · · Business
These are pretty cool, but a little pricey for decals.
Not when you get your hands on them: they are completely different than what people generally know as decals. These aren't single ply vinyl like you may find on eBay or Etsy. These are printed first on the highest quality vinyl and kiss-cut. Laminated over that with 12 mil laminate gloss vinyl or a sandy matte textured vinyl and then carefully aligned to be kiss-cut again. These are thick, heavy-duty, and not like anything you've seen before. And if you buy graphics for your motorcycle that looks like paint and will last you 7+ years, is $100 really expensive?
1 - 7 of 7 Posts
