I made it?Waay Koul !
Who makes it ?
JeppDid not !
Look nice but but what about the warranty when you drill into the steering back?I fabbed my own version. It's more integrated than other designs, but does require some machining and drilling. It's great on the downshift, a little clunky on the upshift since you have to take your hand off the throttle. Also, it is safer at stop lights because you can shift from 1st. to Neutral and back to 1st. gear with both feet on the ground.
Awesome.I fabbed my own version. It's more integrated than other designs, but does require some machining and drilling. It's great on the downshift, a little clunky on the upshift since you have to take your hand off the throttle. Also, it is safer at stop lights because you can shift from 1st. to Neutral and back to 1st. gear with both feet on the ground.
