1 - 20 of 62 Posts
Hello everyone,
I am new to the forum and glad to see that we have other Indian Lovers. I was wondering if any one has found a lift jack that will work on the Indian? I do not have room for a full table lift, and on other motorcycles I have had I just used a lift that fit under the engine area for cleaning the wheels and so forth. Since there are lines that run under the Vintage, I guess I need a special lift platform.
I am also looking for a motorcycle Cover, I have tried 2 different types and none where big enough, is there any company that are making one for the Vintage?
Thanks in advance
Wes
Welcome to the forum, indi!
I haven't heard anything about a special lift yet, but I'll be keeping an eye out now. Let us know if you find something!
Founding Member
I use an aluminum Crewline motorcycle jack. Sears sells one just like it, when lifting my Indian I use hard rubber furniture cups at each corner to keep from pinching the brake lines that run along the right side of the engine. I bought it about 6 years ago and use it on both my Vision and Indian. I think it cost around $260 back then at Sams Club.
Check out the jack from PIT BULL. They are well made and I'e used them on Goldwings and FL Harley's
Founding Member
This is my Crewline aluminum motorcycle jack been using it for at least seven or eight years now. IMG_0854.JPG
I have the ride in cycle shell. I no longer have a garage and this is perfect. ride in does upin about 30 seconds.
Pepboys has a similar jack but it has a lever like a NASCAR jack, so you don't have to pump with your foot. The pressure is removed by twisting the lever. I found it more stable just due to this difference.
No, that isn't the one. That link shows one with the foot pedal. I almost killed myself with one of those.
I don't see it on the Pep Boys site, but I will take pics tomorrow and see if I can find it online.
1 - 20 of 62 Posts
